admin
Ücretsiz 3D Modeller
Batman Gargoyle (ft. Spawn) Diorama
  • admin
  • 0 cevap
  • 12 görüntülenme
admin
Kıdemli üye
Global Admin
  • Katılım8 Eki 2026
  • Mesajlar8.165
Ücretsiz 3D baskı modeli. Paket içeriğindeki dosyalar aşağıda listelenmiştir; tüm dosyaları konudaki İndir butonu ile indirebilirsiniz.
📁 Dosyalar (84):
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/base.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/base_of_the_right_chain.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/body.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/chapel.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/coat_1.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/coat_2.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/column.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/cross.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/gargoyle.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/gargoyle_structure.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/head.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/left_arm.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/left_boot.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/left_chain_base.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/left_chain_tip.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/legs.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/main_coat.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/right_arm.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/right_boot.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/right_chain_tip.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/roof_cross.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/structure_1.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/spawn-gargoyle-part-of-the-batman-diorama-fanart-from-the-comics-model_files/structure_2.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/stl_Batman_bat/stl_Batman_bat/base_batman.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/stl_Batman_bat/stl_Batman_bat/bat_10.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/stl_Batman_bat/stl_Batman_bat/bat_11.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/stl_Batman_bat/stl_Batman_bat/bat_12.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/stl_Batman_bat/stl_Batman_bat/bat_13.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/stl_Batman_bat/stl_Batman_bat/bat_14.stl
  • Batman Gargoyle (Ft Spawn DIorama 3D)/Batman ft SPawn v01 cg pyro/stl_Batman_bat/stl_Batman_bat/bat_15.stl
  • ... ve 54 dosya daha
